Buying From Kspec - Need Help
I'm getting airram, BBTB, short shifter and pulley from Kspec. My question is, which BBTB should I get, that is best / fits the airram intake?
Also, I see that they sell some Tiburon Inazma Wire. I already have some thicker wires, but I can't get the DOHC-plastic lid on top because of the heigth of new wires sad.gif . Will these make in possible?
Thx
Thx
Get between 58-65MM. Personally I'd go with 61MM or less as the Air-Ram is already a larger plenum than stock, with longer runners, and going with a larger TB might cause problems on the low-end in combination with the Air-Ram and exhaust mods if you have any.
i believe the airram size is 68mm.
for wires, i highly recommend picking up a set of the PRD ones proturbotiburon was selling. i ordered a set, and they came out very nice. plus i custom ordered them with a colored heat shielding, and the price was still under 60 shipped.
and they fit under the plug cover quite nicely.
heres mine.
heres mine.
Thanks for the tips guys.
I'd like to order those wires proturbotiburon was selling. Where can I make an order with a colored heat shield? Also, I'm just gonna get the Rside BBTB they are selling at kspec. Probably good.
I'm gonna stay N/A by the way.
