Blowoff valve question
Hey Random, with the Alpine Turbo kit and my 98 tiburon will I need to get a blowoff valve? I am being told that since my car has a mass-air sensor that I will need to get one. Any comments thanks Eric
A BOV would be reccomended. Preferablly a unit that does not vent into the atsmophere, but vents back into the intake pipe as a bypass.
This is the type you are looking for...
http://www.turboxs.com/racing_bypass_valve.htm
No you do need a blow off valve...If you want of course your engine to last long... You see when the turbo spools, high pressure is created before the throttle body...Now, by releasing the gas pedal, the throttle body closes, so there should be a way of releasing the excess amount of compressed air, since, if the throttle body is closed, it is not used anywhere, and it DOES stresses the turbo unit...So if you don't use a BOV you will result with a damage at the turbo, so you will loose alot of money.... Buy one as soon as possible...
The wastegate is placed in a different place, and does another job...If you loke I can tell you exactly what it does, but If I do know I will get alot off the point...
Plus a BOV makes a *very* nice sound...
Hope I helped...
-Tasos-
Hope I helped...
-Tasos-
The units that vent into the outside can make noise or be silent. The unit that vents back into the intake will make noise...but no the "hissing" sound everyone associates with a normal BOV.
In a MAFS car, when you vent to the atmosphere, the car thinks it's getting a lot of flow, then you spray some into the engine bay, so it's dumping fuel for a lot of air, but the air isn't there, because you just vented it.
This can cause surging, stalling, or a really rough idle.
When you recirculate it, the amount of air entering the engine stays the same, albeit at a lower pressure now. The computer can accomodate this.
a
a
