Beta2 Intake Manifold Options
I just got a beta II head for a full port and polish and intend to do the intake manifold as well. While I realize that their are some differences between the manifolds, will they interchange?
If this has been answered before I apologize, I searched and was unsuccessful
the bolt patern works
but the beta1 port are smaller
you can port them to the beta2 size but you need to weld a bit on 2 runners so you don't get a hole once ported
No he is saying if you were to try and bore it to the same size of the Beta2 you would have to add some or you would end up with a hole. In other words, the Beta2 will be better for performance. You can not make the Beta 1 manifold have the same size ports without adding material. Hopefully that clears it up. The beta 1 will bolt up not problem at all.
Not for the beta 2. The beta 2 has different TB bolt pattern and Uses a different style IAC. There is more specific information around here somewhere. Im not positive on the IAC on how it is different off hand
