Beta Max Na Hp
Old 01-31-2009 | 09:35 PM
Tony Vendetta's Avatar
i met this tiburon enthusiast here in L.A and told me that the max hp that the beta can reach na is 220. Is this true or has anyone here reach more than that na.
Old 01-31-2009 | 09:39 PM
UrS0NvS's Avatar
Tell him he is a Tool if he is thinking 2.0. i dont even think you can get 220 with the 2.7 in N/A, probably wrong on that though since they start with around 180.
most i have ever heard is 160 WHP.
I8aCobra's tib
http://www.hyundaiperformance.com/forums/n...ted-9-29-a.html
Old 01-31-2009 | 10:26 PM
maybe i'm mistaken but didnt T_donnell have like 170 somethin?? but he had full internal build with headwork
Old 01-31-2009 | 11:15 PM
I'm just going to ignore this thread.
Old 02-01-2009 | 01:44 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
QUOTE (optimoprime @ Jan 31 2009, 09:26 PM)
He made 157/133.5. I made 164whp right before selling the car, but the last dyno chart I have and only number I can "prove" is 152.15/135.5. I think the only major difference between our cars is that he has oversized valves and lumpier cams. I still think he should be able to beat my 164whp with his current parts if he gets a better tuning solution.
Old 02-01-2009 | 02:32 AM
so the highest recorded na hp is 164 na? wow wat was your mod list when you reached 164 ibacobra.
Old 02-01-2009 | 07:24 AM
badshah's Avatar
Vehicle: 1997 Hyundai Tiburon
An friend of mine can get a "race" head (from korea) which will add about 50hp. With the right cams (colt cams: 8whp), intake (airram & cai: about 10whp?) and exhaust (equal length and 2,5" back: about 10whp?) setup and custom remapping the ecu should take you 200+hp on flywheel. These allong with other upgrades such as lightened flywheel, lighter pullies, etc...
stock beta gives +10hp on tuning a stock ecu, so a modified beta should give a bit more
Old 02-01-2009 | 10:14 AM
HP doesn't add up like that.
If so, I'd be at about 210 WHP.
Old 02-01-2009 | 10:15 AM
i8acobra's Avatar
Sorry, but no head is going to give you a 40% increase in power.
Here's my mod thread:
Old 02-01-2009 | 11:41 AM
so i8acobra you also have a msd ignition in your mod list? you have your ignition timing and rev limit set custom by you?
