Bad Motor Mounts? Help Please
Well umm ... as I asked before to change the motor mounts (lower two). Can I just jack up the engine remove the cross member without removing the wheels, cv joint... etc?
Yes you can remove cross member without CV joints , 2 bolts in the front , 2 bolts in the back , 1 bolt on the front mount , 1 bolt in a back mount and cross member on the ground , make sure you support engine and tranny while doing that smile.gif
