AOS CAI....
Old 10-10-2001 | 02:21 AM
WhoopOi's Avatar
Old 10-10-2001 | 05:41 AM
2K3GT/2K Wagon's Avatar
QuikTib what is your battery sitting on?, did you move the tray?
Old 10-10-2001 | 05:43 AM
Oh...and where did you get the rubber connectors for the pipe?
Old 10-10-2001 | 06:25 AM
QuikTib's Avatar
If you remove your battery you'll see that it is held down with 3 bolts in a triangle pattern, so unbolt it and rotate it 45 deg. toward the engine. With some help from a dremel, the back hole that is closest to the wheel will line up with the hole in the front and then bolt it down again. Since our battery is held on to the tray with the first bolt you have to rig up some sort of strap to keep it attached to the tray, I used some metal screw ties. After the battery is out of the way you have direct access to the hole it was concealing.
I got the rubber connectors from Lowe's in the plumbing section.
Old 10-10-2001 | 11:31 AM
What size are the rubber connectors, all I could find were 3".
Old 10-10-2001 | 03:24 PM
Then you didn't look very hard. Most large hardware stores have everything from 2" to 5" in the "plumbing" asile. YOu can also get high quality silocone units from Hose Techniques.
Old 10-11-2001 | 12:07 PM
ICE3X's Avatar
why won't the AOS CAI fit the automatic's?
i've never seen an auto tib, so i'm not even sure what it looks like under the hood,
i figured they would be about the same.
Old 10-11-2001 | 12:08 PM
ICE3X's Avatar
oh yeah, i have a AOS CAI intake on my 97 tib 2.0
and i like it.
Old 10-11-2001 | 11:45 PM
Cottonmouth's Avatar
CAI's have trouble fitting automatic because of the size of the auto transmission. It almost completely blocks the route of the manual tranny CAI.
Speedstate is developing an Auto AOS CAI right now I believe.
