Anyone who uses FRAM oil filters needs to watch this
Old 10-04-2010 | 07:21 AM
Spirit's Avatar
Vehicle: 2001 Tiburon
Default Anyone who uses FRAM oil filters needs to watch this
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/nfj9KUv0pKY"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/nfj9KUv0pKY" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
Old 10-04-2010 | 11:31 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
So, what's the problem? The end caps are cardboard...is that the issue? My truck has 460,000 miles on it and runs Fram oil and air filters. Don't buy the expensive = better argument.
Old 10-05-2010 | 03:01 AM
Regit's Avatar
Vehicle: 2000 tib
I don't get it? why do I "need" to see this?
Old 10-05-2010 | 06:38 AM
go team ramrod!
Old 10-05-2010 | 05:12 PM
red97tib's Avatar
Vehicle: 1997/Hyundai/Tiburon
So after watching the Mobile One filter tear down I see that all filters are basically the same and I should always buy the cheapest. Check. Waste of time. Check.
Old 10-05-2010 | 05:29 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
Don't do it in your tib...
I had a fram and my hla's went crazy one day on my way to napa to get oil for a change lol. Had to bleed em out, pita
Old 10-05-2010 | 05:48 PM
so after watching the STP, Mobil 1, Purolator, Fram, Bosch, Amsoil .... the only differences are the end caps on some. The Amsoil and Wix have a spring instead of rubber anti-drain back, and the Amsoil has a synthetic (not paper) filter.
I've seen Amsoil being fairly popular on the internet. Is the synthetic filter the reason? For $16, I'll stick with OEM.
Old 10-05-2010 | 08:19 PM
for hyundais
oem is wix
Old 10-05-2010 | 10:13 PM
If we could get a high flow/high volume oil pump, we could use a FRAM also. With the stock oil pump, OEM, Purolator, Mobil 1 etc but no FRAM.
Old 10-13-2010 | 12:33 AM
krazytib's Avatar
I buy like 5 filters at a time from hyundaioemparts.com for $4.90 per filter which is cheaper than aftermarket filters. Almost every filter I have tried caused excess HLA noise compared to OEM.
