Another clutch question...
Re: Air conditioning problem
I just changed my clutch with a stock replacement, and I'm getting a weird clicking when engaging the clutch pedal every now and then. It's like a popping sound and I can feel it on my foot. It mostly happens when engaging first and engaging second, I've also had it happen when engaging reverse. I haven't been able to reproduce it exactly though, it seems to happen rather randomly. The clutch has around 100 miles on it so far. Is this normal for a new clutch (will it go away with usage?) I tried searching around some and found it might be the spring in the master cylinder. Any help on this issue is much appreciated before I grab my ankles for the dealership :roll:
Re: Squeeling Power Steering Belt
Check the cables of the master and slave of the clutch.....
otherwise.... maybe inside there are little pieces of metal in the transimission.... if it so... change the oil...
