advantages to using aftermarket stud kit on n/a car
Vehicle: 00 elantra
would there be any advantages to using an aftermarket stud kit on an n/a car? may be going boost in the future and would it be ok to install these first before the turbo kit was finished? I know these are for a tiburon but its the same engine.
http://www.atomicspeedware.com/20ltiburon.aspx
If you've got a few hundred bucks and just feel like doing it, if you don't screw it up it won't hurt anything. If you are planning even mild boost levels, it's not required.
The real question is: do you want to do it or not?
