97 Octane Gas
Old 05-10-2002, 02:11 PM
Elantra2.001's Avatar
A higher octane rating will NOT give you more horsepower. The here is what the octane rating is. It is the equivalent of the ratio of iso-octne to n-heptane. Gas with a rating of 92 has the same self ignition compression point as a mixture of 92% iso-octane to 8% n-heptane. The reason that higher horsepower cars use higher octane is because of the fact they have hgher compression ratio's, not becaue it gives you more power. If you use lower octane ratings in a higher compression car, it will knock which will break engines. Thank god for knock sensors, which lower the compression by retarding the timeing. If you use high octae fuel, you will waste your money on some small psychological gains that some poeple feel. If you think I'm wrong (which I'm not) then do a little research and you will find out for your self. Have a nice day. wink
Old 05-10-2002, 02:15 PM
Also It's not cleaner, It just has more of the iso-octane. Once again, have a nice day. wink
Old 05-11-2002, 12:35 AM
BV1
BV1's Avatar
Its more refined, it goes through 3-5 more distilation cycles, so therefor it will have less impurities. This is why racecar drivers use 110 Octane gasoline, for purity and Octane rating.
Old 05-12-2002, 01:24 AM
Racecar drivers only put a couple miles on each engine, then get a new one. Why wold they care about impurities in gas. If we can go hundreds of thousands of miles on our low octane "dirty" fuel, then that can't be a serious concern. Race engines also have higher compressions than our cars, thats why they use higher octane. Sure some race fuels are specially refined, put that fuel ccasts so much per gallon that it would be recockulous for us to buy every day. companies like Elf and Agip make that kind of fuel, but its basically the same refineries that make 87 octane as 92 octane and the government regulates that. Besides, you cant argue with the facts I posted earlier. I'm not trying to slam you or anything, put it's the truth, no extra horsepower and all fuel is filtered so the only real contaminants are other hydrocarbon and some trace metals.
Old 05-12-2002, 11:04 PM
Barry's Avatar
Damn, our standard gas is 97 Octane unleaded!
No wonder we pay so much.
Barry.
Old 05-13-2002, 01:48 AM
Other countries use different calculations to get their octane ratings. Your gas is expensive probably because of local taxes.
