1.8 Ecu With 1.8 Intake Cam
Old 07-03-2005 | 09:58 PM
Tibbiette's Avatar
i've tried searches and saw a few posts about them but still unclear to me. I heard that the 1.8 ecu is reportedly better than the 2.0 ecu in a 2.0 tib. But if i had the ecu and a 1.8 cam in my car would that be better or would the 1.8 cam take away from the advantages some how?
thank you!
Old 07-03-2005 | 10:03 PM
zoned019's Avatar
Vehicle: 97 Tib
Don't waste your time on that mod ... get the new aftermarket cams and ecu from RE (check out the vendors section).
With the 1.8 ecu and the 1.8 cam you will get more HP with the combination of the two, however the difference from what I've read (by searching) is not much. IMO, not enough bang for the buck.
Old 07-03-2005 | 10:34 PM
im thinking th e1.8 cam will be my next mod. gotta change the timing belt soon anyway.
Old 07-03-2005 | 11:05 PM
NightShark's Avatar
the 1.8 cam is a good cheap mod.
tibby01, you don't need to take off the timing belt to change the cam
Old 07-03-2005 | 11:06 PM
col96fx's Avatar
Vehicle: Hyosung GT650
You don't need to touch the belt to change the cam.
Old 07-04-2005 | 02:21 PM
i know, im just saying that if im in there, i might as well do that too.
Old 07-05-2005 | 08:02 PM
Boricua's Avatar
I just finished adding my 1.8L cam on my car. It feels great driving it now. Go for the mod you'll enjoy it.
Old 07-05-2005 | 08:13 PM
If you can afford it.. getting the timing belt changed is THE best time to change over to an underdrive pulley.
Any yes, I loved the change in my Tib by going to the 1.8 intake cam. It pulls a little stronger, sounds a little meaner, and there is no downside.. what more could you ask for?
Old 07-05-2005 | 09:43 PM
col96fx's Avatar
I'd say yes, as it would allow more boosted air into the engine.
