1.8 cam part #???
1.8 cam part #???
Hey whats up, i work at a auto parts store soo i get discounts an parts and i want to buy the 1.8 cam for my 2001 tibby. But i dont know which cam it is! What car is this cam coming out of? Like is it just the 1.8 cam from a 97-99 tibby or what? and if any1 has the part number handy that would be great!!! thankz every1
Fred
Fred
You can only get the part from Hyundai. It is the cam from the 1.8L elantra.
We recent found out that the cam from the 2001 2.0L elantra is even better, but since that cam is designed for use with shimmed valves rather than HLA valves like our motors, it may cause problems with your valve springs, it may not. the jury is still out.
I seriously DOUBT that it will cause any problems, as there are aftermarket cams with much higher duration and lift, and they can be run with the stock valve springs.
After talking with a few very knowledgeable engine builders here in the city, I'm of the mind that the 2.0L intake cam from the 2001 Elantras should be fine on our stock springs. We should be perfectly OK to install these on any of the previous motors.
-Red-
-Red-
