Diy - Bbtb Install & Throttle Body Bypass Mod (free!)
#32
I got my car back from the body shop yesterday smile.gif ...so my treat to her was the Throttle body mod and clean the throttle body with Gumot Intake/Throttle body cleaner....after cleaning it I had a CEL sad.gif ...but went away on the way to autozone, I feel the difference with the cleaning...This was an excellent write up and it did not take long to do....Thanks Redz
#33
No problem. You should notice that the engine doesn't lose as much HP after it warms up now too. That effect is even more pronounced after more cooling modifications.
#35
I can't get the ******y coolant lines off either end! They're stuck on both the TB and where it originates from. Any suggestions on how to get the lines off the nipples? (yes, I did remove those clamps...)
SE
SE
#38
Neither of the above. It's actually pretty easy. Stretch them out just a bit, get a pair of slipjaw pliers, and twist the rubber around the nipple a bit. Should break loose.
#39
oh cmon, just take a stanley knife and cut that fugger vertically. then pony up $ 0.45 for 3 inches of small coolant hose to make a loop if you dont have something lying around lol.
#40
The other problem was just trying to get in there at it!! I didn't take off the TB, just my CAI going into it, and it was sooo hard to even get at the clamps! Redz, what do you mean stretch them out a bit? Do you mean after they're off to get them back on?
Thanks for all the advice guys!
SE
SE
