Water Leaking In
This is a common issue with cars that have been in an accident, if this is not the issue it's just the weather stripping. After a while the rubber will actually shrink due to weather (heat, rain, cold, snow) The major culprit is heat. I don't think aftermarket replacement weather stripping is that much. Also make sure the drain holes in the spare tire boot not clogged. If you don't have any holes ........ make some.
