Wheel Spacer?
Vehicle: 2004 Acura TL
boosting a MAP based car
I agree :pic: smile.gif
you shouldn't have to reset anything. Just make sure you coincide with this link
http://www.rdtiburon.com//index.php?name=F...viewtopic&t=845
Re: Exhaust Help
Yea all i have done so far is new wheels. Going to do some of the DIY this weekend when i change my brake lines. Will also post some pics soon. I was just wondering about resetting it since some say to do so after anything you add or change on the car. Thanks for all your help.
Re: How much water gets inside the doors?
if your wheel/tire combo is sized properly you shouldn't have to reset the ECU.
If they DON'T keep the overall profile of your stock rims/tires you need to have your speedo calibrated......this is NOT done by resetting the ECU. you have to take it to a shop to have it done.
Re: deactivate map light
wheel spacers would probably do it, only thing is if you get a set that are flush in the back you're screwed and still have to take out the screws (i drilled mine out) then sanded everything down.
Anybody have a link to a nice set of well-machined wheel spacers? I don't need much offset increase, just in the back a lil bit, i'd like to see the wheels match up with the wheel well... Thnx
refer to page 1 of this thread (even on to page 2) : http://www.rdtiburon.com/index.php?name=Fo...=viewtopic&t=22
It'll answer all you're questions about those screws and the difference between captive and non-captive rotors.
Re: Blown Clutch?
I just suggest to be carefull with wheel spacers, they work great for show but it you're going for a decent track time your asking for trouble. And by track times I don't just mean at the track. Everyday beating takes it's toll on those.
Re: ECU .. SAFC all the computer management for 01
I have H&R 25 mm spacers on the back of my Tib, I have some pics here somewhere I can send to ya! Whats your email?
Re: boosting a MAP based car
Once again i thank everyone for all the help. I just have one more question. Im mounting my rims now but have no idea how much torqe to use ive looked around and cant really find much on it. Does any one know? Thanks again!
Re: FS: Brand new 340cc BETA II injectors
Thanks a bunch. Will post some pics tonight after i give her a bath!
Ok here are the pics i said i would post. Once again thanks for all your helps. couldnt have done it without you!
These are ADR DV-8 17x7 rims and Falken 205/40/17 Ziex Tires. Handles great and rides so much smoother than stock!
Guess that didnt work. I posted them in the gallery if you wanna take a look!
http://www.rdtiburon.com/index.php?name=co...rmine&cat=10242 sad.gif/http://www.rdtiburon.com/index.php?...&cat=10242
