TIre changes
Guest
Posts: n/a
TIre changes
I've got a set of 215/60R/15's on a 95 pontiac grand am I would like to switch out with my original stock tires for now. I was wondering If they would fit on the original rims (They Should) And if I would rub at all. I think they might be a little taller but not by much. THe only reason why I want to change them out is the fact that they are wider than the originals and they handle great on the grand am. The tires are BFGR touring T/a's. I'd be dong this till I can get a set of 17's.
[ September 13, 2001: Message edited by: hawaiibullrider ]
Those tires will throw off your speedo by quite a bit, and they might rub. They are going to show 55 MPH when you are actually going 60, and they are 1.75" taller than the stock tire/wheel combo. They will more than likely rub.
