Suspension does't feel right
Just because your car tracks straight doesn't mean your alignments not off. You might be towed in like 3/8" of an inch and only notice the effects during cornering cause the car will handle like crap.
A quick way to check with a friend is park on level ground with the tires straight then grab a tape measure and measure the distance between the front tires from the back side of the tires then again from the front side and see if there is a difference. Also some tires make it impossible to be accurate but you can still get an idea.
