Sucky Day For Rims...
Old 04-12-2005, 08:40 PM
97tibby's Avatar
Vehicle: 1991 Olds Cutlass
Okay, so today i brought my car into Bauer Built to get my tires all aligned and put on. When i go out of school my dad called and told me that they could not install any of the tires. Ordered the wrong lug nut size. And then to make things worse, they could not put them on because of the bolts/screws on the rotors so they will not line up and straight on the rim. So they could not put them on, anyone else had this problem? And what is the best thing to do? Thanks.
Old 04-12-2005, 08:45 PM
OdessitPashka's Avatar
Go to any autostore and get some new lugs. We have 12X1.5
Take the screws out, you don't need them, unless you have captive rotors.
Why coulldn't they put tires on?
Old 04-12-2005, 09:00 PM
97tibby's Avatar
97 tib.. so i think i got captive rotors. New set of lugs on the way. They mounted and balanced the tires, but will not put on car because of the screws.
Old 04-12-2005, 09:01 PM
DzSypLX's Avatar
QUOTE (97Tibby @ Apr 13 2005, 02:40 AM)
Are these new rims you never put on before?...If they are i'm guessing' it's not captive rotor compatible and you'll need different one's...since you have a 97 tib therefore you have captive rotors and if your rims don't have the space for the things that stick out then you can't put them on.
Old 04-12-2005, 09:05 PM
97tibby's Avatar
we are just going to screw holes in the back of the rims, lining up with the screws so it will fit on. Either that or just get spacers.
Old 04-12-2005, 10:33 PM
AEMTIB01's Avatar
when i got my rims i thought they were all bent then i realized about that screw in the rotor, (01 tibby) and i took them out..no problems yet.and i have had the rims for about a month now..so just take them out..im still not sure wtf captive and non captiv is lol
Old 04-12-2005, 11:31 PM
OMG lugs are the least of problems. i can't believe how easy that is to solve. are you talking about the lug pattern being wrong, or lug nut size?
you have captive hubs. you will have to go to a mechanic and have him swap the captive rotor hubs to 2000 spec hubs. it'll cost ya around $400. just ask to swap the hubs to 2000 tiburon model hubs and you will be straight. there is no other way.
Captive Rotors & Hubs: Frankenstein bolts that stick out of the wheel hubs. 80% of aftermarket rims will not fit over the bolts.
Non-Captive Rotors: Any rim with the correct lug pattern will fit flat onto the rotor and hub.
Small Screws in Non Captive and Captive rotors: You can take them out, unscrew them, or saw them off. They were only used to hold the rotors in place during assembly.
Old 04-13-2005, 12:33 AM
the small screws you can take out are only on the non-captive setup.
switching to non-captive is not the only option. you could get a machine shop to put some holes in the back of them. some shops wont do it though, as it can weaken the wheel and easily cause un-fixable balance issues.
Old 04-13-2005, 04:41 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
To put on my winter wheels (steel rims) I had to drill 4 holes on each front wheel.
Now I want to swap to non-captive hub.
Old 04-13-2005, 05:21 AM
javageek's Avatar
Check to see if TibbyChick has any rotors left. I have my original four, they would probably need to be taken to autozone and resurfaced or whatever it is they do.
