Stock Offset?
Old 10-24-2005, 11:48 PM
xtremeskier's Avatar
Would i have any rub, do you think. I don't plan on lowering.
Old 10-24-2005, 11:55 PM
I don't think so, especially on stock suspension... I bet you'll want to lower it further down the track though.
OP ran 215/40-17 tyres with a 2" drop & only rubbed occasionally. Worst case scenario, you may need to get the guards rolled if you do lower it.
Old 10-25-2005, 12:00 AM
haha, yeah probably.
Thanks for the help man
Old 10-25-2005, 06:01 AM
QUOTE (OzFxCoupe @ Oct 25 2005, 01:36 AM)
Use the Miata tire caculator to check all the numbers... I think it's a sticky somewhere fing02.gif
Top of this section has a sticky.. it is in the first post.
Old 10-25-2005, 07:50 AM
tdonnell's Avatar
You might even consider getting a 225 series tire because I have 7" wide rims and my 215's are even with the edges of the rim. Just a suggestion, but I know that would probably make rubbing even more of an issue.
Old 10-25-2005, 11:00 AM
funkypc's Avatar
Your buying new Rims? thats Awesome. However, do you still have captive rotors in the front? from what I understand, most aftermarket rims wont fit until you swap to a non-captive setup.
Old 10-25-2005, 02:47 PM
KayJai's Avatar
He's got a 99 According to his profile, so he's fine
Old 10-25-2005, 05:39 PM
What years do you have to swap rotors? Isn't it like 00-01??
Old 10-25-2005, 06:36 PM
funkypc's Avatar
QUOTE (KayJai @ Oct 25 2005, 03:47 PM)
Dangit. All I read was the new member FAQ.
http://www.rdtiburon.com/index.php?showtop...=captive+rotors
It just makes the distinction between 1st and 2nd gen tibbys.
So in answer to Xtremes question, the years you have to do the swap are 97-98. Any tibby after that should be fine.
Old 10-26-2005, 05:30 PM
Ok, well i think for sure i'm gonna get the Konig Prophets (17 X 7.5). Do you think i would be able to get away with 225/40/17 tires without ANY rubbing. I'm all stock right now (not lowered). Or would it be a better idea to go with the 215/40/17's.
Also any opinions on the rims are welcome!
Heres a better pic.
http://www.wheelsworld.com/2106-1999-Volks...t.html?size=big
Thanks!
Sorry, going with the 215/40/17's.
