Rims Finally Installed.
Old 04-17-2005, 12:55 PM
97tibby's Avatar
Vehicle: 1991 Olds Cutlass
alright guys, i just went outside and made sure they were not touching the captive bolts, and they are not. I went to put them back on and they would not go on*meaning lugs* i do not think they are the right size, they go on, but only at a certain angle and i dont think thats how they should be, threw my old rims on the front and i have no problems what so ever. Any one got the correct stud sizes for a 97 tib and any advice. Thanks laugh.gif
Old 04-17-2005, 03:02 PM
it almost sounds like you got the wrong bolt pattern
Old 05-01-2005, 03:39 PM
Rd1tib's Avatar
any update on what you did?
Old 05-01-2005, 03:50 PM
97tibby's Avatar
yeah, they are on. We had to drill out the back of the rims so that the captive bolts on the rotors would fit. Shakes at like 40+ mph, going to have the tire place balance the tires again and try a set of hubcentrinc rings or w/e their called. Any of you guys had this problem and the rings fix it? Please give me any input. Like how they look. But not the shaking. 02.gif
Updated pics
Compilation of Pics
Side View
Interior
Old 05-01-2005, 05:49 PM
UltraTibby's Avatar
Ouch drilled out the rims? You are nutty! Should have just swaped to noncaptive. I would put money on it the rims are trashed......
Old 05-01-2005, 06:26 PM
Rd1tib's Avatar
i see, fill us in when you get your hub centric rings on. How much u pay for the rings?
Old 05-01-2005, 06:44 PM
CyberShark's Avatar
hubcentric rings are not that expensive. Try to get the metal ones if you can. I had forgotten to place hub rings on my wheels a while back and my steering wheel would vibrate at highwayspeeds. When I put them on, the probelm was eliminated.
Old 05-01-2005, 06:54 PM
Rd1tib's Avatar
im sorry if im taking up this thread. Hub Centric- one size? can you use it with your oem wheels as well?
Old 05-01-2005, 08:14 PM
OdessitPashka's Avatar
you trying to make your car look exactly like the one on the picture, aren't you?
It's not bad I guess, I a little ricey IMO, but w/e floats your boat man.
Old 05-01-2005, 08:54 PM
KayJai's Avatar
QUOTE (rd1tib @ May 1 2005, 07:54 PM)
You don't need it with OEM wheels. They fit perfectly around your hubs
Hotrod had his rims drilled out to fit over his captive rotors, no problems for like 5 years now.
Mind you he did it right, got a certified shop to do it correctly,... not sure how you went about doing yours
