Need answer quick to this Q.
Vehicle: 1997 Tiburon
Are 1997 Accent GT non captive rotors, brake lines and pads the same as non captive Tib set up? If not what is the same?
Thanks guys.
Thanks guys.
Checking WebTech, no they're not the same. The Accent brakes are smaller than the Tib's. Can't answer your second question though. You may want to check WebTech and compare specs from the different models.
Vehicle: 2004 Acura TL
The difference is the size of the rotors. They are still captive but smaller. I dunno about the rest. As they are smaller cars I would assume they are different parts.
