Longer lugs?
Longer lugs?
I plan on getting 2" wheel spacers for the front and back of the tib, due to molding in some new fender flares over the winter. Will I need to get longer lugs, or will the stock ones be fine?
Vehicle: 2008 Hyundai Tiburon v6 SE
do you mean longer wheel lug studs? If so and you have a tiburon....pm me. It's a headache to find the right sizes and I had to search for it for about 3 weeks....but I have the sizes, length, knurl, thread you will need.
Pat Cournoyer has 2" spacers on his tib:
My fender flares wont be as wide as his. They're more low profile, but I do want my rims to be as flush as possible.
V, you'll need to get an adapter, not a spacer. You'll bolt it on with your lugs and it'll have another set of lugs that you bolt the wheel to.
Found these on ebay:
<object width="355" height="300"><param name="movie" value="http://togo.ebay.com/togo/togo.swf?2008013100" /><param name="flashvars" value="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=370300692366&query=unlocked%20iphone%203g&campid=5336025580" /><embed src="http://togo.ebay.com/togo/togo.swf?2008013100" type="application/x-shockwave-flash" width="355" height="300" flashvars="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=370300692366&query=unlocked%20iphone%203g&campid=5336025580"></embed></object>
<object width="355" height="300"><param name="movie" value="http://togo.ebay.com/togo/togo.swf?2008013100" /><param name="flashvars" value="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=360213176398&query=unlocked%20iphone%203g&campid=5336025580" /><embed src="http://togo.ebay.com/togo/togo.swf?2008013100" type="application/x-shockwave-flash" width="355" height="300" flashvars="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=360213176398&query=unlocked%20iphone%203g&campid=5336025580"></embed></object>
<object width="355" height="300"><param name="movie" value="http://togo.ebay.com/togo/togo.swf?2008013100" /><param name="flashvars" value="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=360135662910&query=unlocked%20iphone%203g&campid=5336025580" /><embed src="http://togo.ebay.com/togo/togo.swf?2008013100" type="application/x-shockwave-flash" width="355" height="300" flashvars="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=360135662910&query=unlocked%20iphone%203g&campid=5336025580"></embed></object>
But even the 25mm one is only one inch.
You would want one like this:
<object width="355" height="300"><param name="movie" value="http://togo.ebay.com/togo/togo.swf?2008013100" /><param name="flashvars" value="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=230407375338&query=unlocked%20iphone%203g&campid=5336025580" /><embed src="http://togo.ebay.com/togo/togo.swf?2008013100" type="application/x-shockwave-flash" width="355" height="300" flashvars="base=http://togo.ebay.com/togo/&lang=en-us&mode=normal&itemid=230407375338&query=unlocked%20iphone%203g&campid=5336025580"></embed></object>
Vehicle: 1997 RD 4-door
you might want to get a hub centric spacer, or get the proper lug centric lugs,
oversize wheels and spacers will put huge stress on wheel bearings, and the front one's are a pain in the arse to replace
