Lightest Rims Avaliable?
Old 08-06-2001, 12:44 PM
thespitefire's Avatar
Default Lightest Rims Avaliable?
Does anyone know of or have a list of some of the lightest 17" rims avaliable? Eventually I want to upgrade to something better than the stock rims, and while I am trying to find something that looks really good, I also want to avoid loosing preformance over it. I love the look of the bigger rims..but loosing speed due to extra weight kinda stinks. Was wondering if anyone could help me out with this smile.gif
-Hans
Old 08-06-2001, 03:35 PM
Viper966's Avatar
u can buy carbon fiber rims...
Old 08-06-2001, 06:03 PM
Volk TE-37's are the best quality/weight/durability, but they will run you about $400 to $500 a wheel.
SSR makes a similar wheel called the "SSR Type C" but it is not available in the USA at this time. ($350 to $400 a wheel)
Fiske makes killer lightweight/durable wheels, but none in 4 lug.
The Budget alternative is the Enki RP01. Almost as light as a Volk...but only about $125 a wheel. Not too sure about their durability/quality though (eneki are known to be decent rims, so I would give them the quality, but I dunno about the durability).
[ August 07, 2001: Message edited by: Random ]
Old 08-07-2001, 12:56 AM
Greg Daeity Garcia's Avatar
SSR makes a light weight one called the SSR Competition, it runs 300-400, slightly less than the TE37s
Racing Heart has a few
ALT has the light speed, but i think the biggest is 16, maybe 17
Axxis just came out with a pretty light one
Old 08-07-2001, 02:35 AM
ShngstarR's Avatar
racing hart has the cp-035...they have 17's and are about 13.5 or 14.5 lbs. a peice...konig also makes a lookalike that is called the subzero that is a lot cheaper in price.
Old 08-07-2001, 04:03 AM
RedShark's Avatar
So what is the weight of the stock rims?
Old 08-07-2001, 05:10 AM
Stock alloys are 28 LBS each if I remember right. That does not include the tire, just the wheel.
I've got a line on some old wheel/tire combo's, so I should have 100% accurate numbers on this within 2 weeks.
Old 08-07-2001, 05:43 AM
RedShark's Avatar
Cool. So am I to assume correctly if the aftermarket wheels are under 28 lbs, no matter what the size, that it won't cause a decrease in power? I really like the look of 17's but I DO NOT want to hurt the performance of my car for a cool look.
Old 08-07-2001, 05:52 AM
*BUUUUUZZZZZZ* wrong...thank you for playing. (Don't worry, i won't call you a weakest link or anything like that).
Wheel weight is a factor, yes. However, the distribution of that weight more important.
The farther out from the center of the wheel the weight is, the WORSE it is. Thus 17" wheels are worse than 15" wheels of the same weight assuming equal weight distribution for both wheels.
Then add in the heavier Tyre on the 17" wheel, and you make the problem even worse, as the Tyre is farther out than the edge of the rim.
In general...smaller is better, lighter is better.
Old 08-07-2001, 06:55 AM
YellowShark's Avatar
Vehicle: 2012 Hyundai Veloster
My 17" Quautum-Tec S-10z w/Yoko'A520z weigh the same as stockers. 45lbs.
