How To Change Bushings On Rear Stabilizer
Yeah basically. It is easiest to remove all four bolts (two from each mount) from both sides then put the new bushings on and then bolt them back down. With only one bushing mount off and the other one on you will have some trouble getting the bushing off. Easiest to just take both off then put both back on.
