help quick
You can relocate it anywhere, following these restrictions.
#1. The sensor must maintain it's current "north/south" orientation. If you reverse it 180 degrees, it will not work right.
#2. It must be mounted to the frame/body, not mounted to plastic, rubber, or to the engine.
Vehicle: Custom Wagon
I had to do it that because I still had the orignal air box in there. And there was no room to put anywhere else but there. But as long as it works I'm going to keep it there.
