help fast please!!!!!!!!
ok i want to order some 17" lightweight racing rims from www.street-looks.com it is the rs-22 from arospeed.....anyone have any opinions..... they are only $500......and also does anyone have or can you find a discount code for that site..... Thank you all a bunch
Joey
Joey
There is not enough information there to decide if those will fit a tiburon.
You need bolt pattern and offset information.
Also..how light is light? They don't list the weight.
They also don't say what they are made of. They are charging $125 a wheel. Enkei RP01 or ER01 are the same price from www.tires.com and those ARE light wheels.
If I remember right, the stock tibby alloys are 28 lbs. but I do not know if that is with tire or without tire. I will be getting new tires put on my old stockers, so I should know soon.
Above: From you Random.....
Did you find ot if that is with the tire or not??.....is 21lbs a rim good....if is with the tire how much do tires weight? hmmmm
and ok ok so if the new rims i want weigh 21 lbs a piece and the kuhmo tires 205/45ZR17 88W = 21.8 lbs also weigh 21 pounds does that mean that each rim/tire would be 42 pounds??? please tell me no.....if so **** getting rims.....
[ December 13, 2001: Message edited by: Mister694 ]
If they are 21 lbs...that is NOT light.
I would call "light" anything under 17 lbs in a 17" wheel.
Yes, the stock 15" wheels are fairly light. My 17" Konig Rated-R's and tires were 42 lbs each.
The stock set I weighed were 35 lbs each for wheel/tire. I think the stock wheels are about 15-17 lbs, but I won't know for sure for a couple of more weeks yet.
[ December 13, 2001: Message edited by: Random ]
