Eibach Pro System Vs Pro System Plus
Tirerack Link
There's a $400 price difference on Tirerack and from what I can see, the only difference is the sway bar.
Won't it make better sense to just get the sway bar later at a cheaper price?
You save $20 getting the Pro system plus with the sway bars including, than if you were to go and get the Pro system AND THEN the sway bars separately,... I don't see what the problem is there,...
It's better to get it as a combo then to buy it separately,...
No, they include both sway bars, front and rear.
If you have the money, go for it because springs make 50% of the improvement, and swaybars make the other 50% (OK if you want springs 40%, Sway bars 40% and shocks 20%).
Eibach shocks are expensive compared with KYB GR2, you could buy the ProKit spring set, and the Sway bar kit only, that should sum like $620 and then get the 4 KYB GR2 for ~$220, totalling ~$850 so it's up to you if you want to save the difference.
Just an FYI:
I scored the KYB GR2's off eBay a little cheaper than what TireRack sells them for, from a Vendor called Sparkplugssource
It's around $40 cheaper depending on shipping, but (for me anyways) forty bux is forty bux. Just thought I'd pass on the info.
-Fran
-Fran
