Diy Strut Bar
really not much of a diy here guys.
cut center pipe to length and cope both ends.
cut end pipe pieces and weld a washer on each one (easy way)
tack all together, clamp it all down in a way so that both ends are square with each other, weld.
shouldn't take more than two hours tops and that is taking smoke breaks,lol.
Yes & so are these http://www.rdtiburon.com/index.php?showtopic=18082
IMHO to much stress on 1 bolt.
QUOTE (col96fx @ Jun 25 2007, 04:57 PM)
heres a newer picture
im going to just add a piece of flat bar in between the 2 bars, to make it that much stiffer
^ I see you've added another bar though. A single bar with 2 - or even 3 - mounting points at each end would've been tidier.
Still, if you weld them together, it'll get the job done.
