AirRAm+Strutbar=DONE!!
Re: 1000hp RD2
Doode, if you can make me a set of brackets I'd love it. Only problem being who around you has my FSB?
:roll: wink.gif
:roll: wink.gif
Re: Post Count
its actually an accelerator sensor. heres a little description off of webtech on what it does...
accelerator sensor..
knock sensor...
even so, im sure you could still do Redz's little DIY to fix the problem. it might require a little extra amount of bending on the braket to get it to fit nicely.
comparing the two, it looks close.
The acceleration sensor is attached in the engine compartment on the driver's side. While driving, the rough road condition is sensed by the acceleration sensor and the ECM uses this input signal to avoid the wrong misfire detection.
knock sensor...
