ABS light...What can it be?
Old 03-12-2005, 09:04 AM
gsasha1's Avatar
Vehicle: tiburon 1998
Default ABS light...What can it be?
Hallo,
I need your help:
My ABS light is on. what should i doo? Brake fluid level is OK, and it stops the same...?
Old 03-12-2005, 09:05 AM
Hmm, might wanna check at webtech and see what the troubleshooting procedure is.
Old 03-12-2005, 09:17 AM
probably something electronic. Could be a bad sensor, a sensor ring (on the hubs) bad wiring, even a burned out fuse..
Moving this to braking.
Old 03-12-2005, 11:30 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I have same problem.
Sometimes ABS light turns on and when I turn ignition off and then start the engine it will be ok.
I have problem with rear sensors, I think they are dirty or something with wiring.
in summer I checked ABS error codes:
34 - rear right sensor airgap.
73 - rear left exciter wheel speed.
What is exciter wheel speed?
Old 03-12-2005, 11:53 AM
hamhead's Avatar
Mad-Machine is right on this one... I agree 100%. If you reset the ECU does it go away? On my Mom's Forester if you hit the brakes hard the ABS light will come on. I drove it home and reset and the brakes were fine, ABS worked.
Old 03-15-2005, 08:08 AM
gsasha1's Avatar
Tried re-seting...
Nope, still on..... What can i Do?
In Israel, they charge about 50$ (!) to just check what codes the ECU is having.....
50!!!! just for plugging that little diagnostic device!!!!!
HELPPPPPPPPP!
oh yes,
Didn't check the fuse issue . will do.
Old 03-15-2005, 08:23 AM
Dmitry's Avatar
^^^ you can check code number with usual bulb (better with LED)
check here
http://www.hmaservice.com/webtech/iindex.a...id=12288#_12288
Old 03-15-2005, 08:33 AM
gsasha1's Avatar
Thanks man.
How do i do it exactly? did you try it? can it damage the ECU?
Does the ABS itself flashes during the check???
Old 03-15-2005, 09:05 AM
Dmitry's Avatar
I thoght it would be ABS lamp in the gauge cluster flashing. But on my 1997 Korean RD it wasn't.
So took 2 wires 1 LED and connected it to the same pin as in webtech, like this:
+ data connector pin(under dash) - wire - LED - wire - ground.
and it flashes.
But I didn't find that error number in code list.
Old 01-28-2006, 11:37 PM
hardate's Avatar
Anyone every find out what causes this? Mine just came on tonight while I was driving it. I haven't tried anything yet, but thought I'd check here 1st.
