About the big brake upgrade
Guest
Posts: n/a
HEY guys,
I was wondering if my tibby has captive or non captive rotors.
One thing i can tell you
When i changed my front rotors first time my mechanic was hitting very hard the rotors to dismantle!!So is it captive?
All the above because i am planning to buy the SR big upgrade brakes.
Furthermore what kind of pads does this system use?Will i be able to find these pads here in Greece?
Also how can i pay sharkracing and get my brake system?
If you have 4 bolts plus 4 lug studs you have captive rotors
If you have 4 lug studs plus 2 screws, you have non-captive rotors.
The pads are the pads for the XG300, so you should be able to get them locally, but you might want to order the "performance" set through Sam rather than the typical pads you can get locally.
You can arrange some method of payment with Sam. Since the Big brake kit is damn heavy, and so are the coilovers...you MIGHT get a discount if you bought both together and had them shipped together.
